16 years agoMinimal MMU linux hangs on DE1 board
Hi all, when trying to build my first MMU linux on a DE1 board system hangs just after nios2-terminal with:
nios2-terminal: connected to hardware target using JTAG UART on cable nios2-terminal: "USB-Blaster [USB 6-1.1]", device 1, instance 0 nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate) Linux version 2.6.34-00692-g5bc7853-dirty ([email protected]) (gcc version 4.1.2)# 62 Wed Jun 23 19:31:26 CEST 2010 bootconsole [early0] enabled and that's all. The system is a bare minimum one comprising only:- linux_cpu (JTAG_debug at 0x07ff_f800)
- linux_timer_1ms (0x0840_0000, IRQ 11)
- fast_tlb_miss_ram_1k (0x07ff_f400, both slaves)
- cfi_flash (thru tsb_cpu_cfi, 0x0000_0000, 4MB)
- sdram (0x1000_0000, 8MB)
- jtag_uart (0x0840_0020, IRQ 1)
Sorry i forgot to tell, i am using DE2-115 Development and education board.
Hi, I am using device tree to compile the kernel. After i load the image kernel starts booting but stops at
Switching to clocksource timer msgmni has been set to 249 turn off boot console early0 after that no prints.. In the kernel menuconfig i have enabled force default kernel bootargs and i have given bootargs as "debug console=ttyJ0,115200". What could be the problem ?? Need help Thanks , Tejeshwar - Altera_Forum
Hi
I have the same problem as mcesar had. He had (1175k kernel code, 3048k data) in his kernel booting debug. This is similar to my situation. (1872k kernel code, 4012k data). How to make data smaller?
