20 years agoMicrotronix linux doesn't appear in Nios II IDE
I have winXP SP2, Quartus II v5.0. I was working with Nios II v1.1 and µClinux for nios 1.3 and everything was all right. After I uninstalled the both last Soft (µClinux then Nios II v1.1) I've i...
15 years ago --- Quote Start --- can i build the linux for Nios 2 using window environment PC? --- Quote End --- No. It does not make any sense to do Linux development - be it system or user space - on a Windows PC. If you don't understand how Linux works on a PC, don't try to use it in an embedded device. For some initial tests you can use Virtual Box to install some standard Linux (Suse, Debian, ...) on your Windows PC. -Michael
