20 years agoMicrotronix linux doesn't appear in Nios II IDE
I have winXP SP2, Quartus II v5.0. I was working with Nios II v1.1 and µClinux for nios 1.3 and everything was all right. After I uninstalled the both last Soft (µClinux then Nios II v1.1) I've i...
15 years agoYou need to read in the NIOSWiki., Its a lot harder to use since it has been integrated in the Altera WIKI, but the information should still be there.
http://www.nioswiki.com/ BTW, you can't "load" or "install" Linux for NIOS you need to _build_ it. -Michael
