20 years agoMicrotronix linux doesn't appear in Nios II IDE
I have winXP SP2, Quartus II v5.0. I was working with Nios II v1.1 and µClinux for nios 1.3 and everything was all right. After I uninstalled the both last Soft (µClinux then Nios II v1.1) I've i...
15 years agoi am trying to load Mircotronix uClinux into my DE2 board using Quartus 2 9.1. There is a problem i cant get to the kernal menuconfig . I dun understand what it mean by Upload using command line.After i install mircotronix with the quartus 2 9.1 This msg show on my command shell
removing old path, because a copy of cywin1.dll was found at: /usr/bin/cywin1.dll what is the problem here
