20 years agoMicrotronix linux doesn't appear in Nios II IDE
I have winXP SP2, Quartus II v5.0. I was working with Nios II v1.1 and µClinux for nios 1.3 and everything was all right. After I uninstalled the both last Soft (µClinux then Nios II v1.1) I've i...
20 years agoHi huanghe,
<div class='quotetop'>QUOTE </div> --- Quote Start --- I should find the 'Microtronix Nios II' sub directory in the Nios II IDE .However, I find nothing.Should I need to do some steps to configue the environment after the installation.[/b] --- Quote End --- There's a little trick about that, in fact you got to execute the SOPC Builder at least once before using µClinux. And verify you're using µClinux 1.4, otherwise, it won't work with Nios II V5.0. And let me know if it still stuck. Warm Regards
