20 years agoMicrotronix linux doesn't appear in Nios II IDE
I have winXP SP2, Quartus II v5.0. I was working with Nios II v1.1 and µClinux for nios 1.3 and everything was all right. After I uninstalled the both last Soft (µClinux then Nios II v1.1) I've i...
20 years agoTry to look at your environment variables and path settings.
I have Quartus 5.0 and NiosIDE 5.0 with uClinux 1.4. I had some troubles with cygwin, so I uninstalled everything then did a regclean and installed it again, then it worked. After I updated to the 5.1 versions I have some troubles with microtronix uClinux 1.4 because 5.1 tools are not yet supported. With 5.1 tools upload has to be done from the command line.
