15 years agoMemory verification issue
Hi all, I have ran into a problem when running Simple Socket Server. When i am trying to run the program (from on-chip ram memory ) i get the verify failed message : " Verifying 00600020 ( 0...
15 years agoWell, i got a non-comforting solution.This error has nothing to do with program size.I can't run "hello world" example either.I have just removed some added mega-wizard component (altclk) and the error was removed .The thing is that i bump into this error numerous times:
-When i try to get nios to work above certain frequency (125 Mhz) -when i connect sg-dma controller descriptors to descriptor memory instead of ssram bridge (as in standard ethernet example) -when i connect 125 Mhz (different) clock output to txclk of TSE mac and altclk component to output (in order to get connection of GMII ) Anyone has run into similar issue(s) or was it just me ? :)
