15 years agoMemory verification issue
Hi all, I have ran into a problem when running Simple Socket Server. When i am trying to run the program (from on-chip ram memory ) i get the verify failed message : " Verifying 00600020 ( 0...
15 years agoSorry. I wrote 'addresses' because this is what sopc builder eventually generates for system.h file,
but I meant the memory where you want to place the vectors: this is what you actually select in Nios properties. So, keep the predefined offsets and try to change the memory selection.
