15 years agoMemory verification issue
Hi all, I have ran into a problem when running Simple Socket Server. When i am trying to run the program (from on-chip ram memory ) i get the verify failed message : " Verifying 00600020 ( 0...
15 years agoI assumed that you used the exact same FPGA configuration for the first simple programs... Does it meet all timing requirements?
Did you use different addresses sections for exceptions/heap/stack between the simple socket server and the other applications you tried? are you sure you have enough on-chip memory to fit the entire SSS application, including stack and heap?
