15 years agomemory transfer rate on a EP4CE75F23CN with MT47H16M16BG-5E
Good morning, I have a data rate problem with DDR2. I had to developp an electronical board for image processing in real time. I used the 3c120 development kit as prototype wich contain a EP3C...
15 years agoHi,
To sum up, In order to improve the transfer rate, I have to allow burst on the - NIOS IP - Clock crossing bridge Do I need to modify something on the uClinux make menuconfig or in the config.c ? Do you think the different will be important ? In the past I already try to make burst transfer under uClinux but I never succeed... Thank in advance.
