15 years agomemory transfer rate on a EP4CE75F23CN with MT47H16M16BG-5E
Good morning, I have a data rate problem with DDR2. I had to developp an electronical board for image processing in real time. I used the 3c120 development kit as prototype wich contain a EP3C...
15 years agoI don't use burst on the NIOS II, neither on the Clock crossing bridge (which is between the NIOS and the DDR2 SDRAM controller).
However I can see "Memory Burst Length = 4" In the parameter of the MT47H16M16BG-5E in sopc builder. I attach the DDR2 parameter that I entered. To create this preset, I took the "Micron MT47H16M16BG-37E" preset which is include in the list preset as default and I change the "CAS Latency" from 4 to 3". Did I make mistake ?
