15 years agomemory transfer rate on a EP4CE75F23CN with MT47H16M16BG-5E
Good morning, I have a data rate problem with DDR2. I had to developp an electronical board for image processing in real time. I used the 3c120 development kit as prototype wich contain a EP3C...
15 years agoWith a simple program running on the nios. It create files which contain 100ko of 0. Those file are rewritted in a loop.
I know that those figures are not correct, however the result should be the same on the two boards.
