21 years agoMemory Test
I was trying to write a simple program to test a board with a Cyclone and SRAM memory. Before hardware, I thought I would do a simple test to the IDT memory on a Cyclone Development Board. I have defined .text, .rodata, and .rwdata as sram_0 in IDE. My sram_0 is defined in system.h with a base of 0x00800000 with a width of 1024 Kbytes. Reset and exception are at 0x00800000 and 0x00800020 respectively as defined in SOPC. I get the very strange messages about sram_0, my defined memory not being within region .sram_0, and also that sram_0 is full section .bss. What does this mean? Can I use IORD and IOWR for access to Memory or should I be doing something else? Any tips appreciated. Thanks, -Ray ERRORS: ********************************************************* Kind Status Priority Description Resource In Folder Location Error /cygdrive/c/Altera/kits/nios21_1/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1/../../../../nios2-elf/bin/ld address 0xbf8150 of simple_axiom_test.elf section .sram_0 is not within region sram_0 simple_axiom_test line 0 ********************************************************* Kind Status Priority Description Resource In Folder Location Error /cygdrive/c/Altera/kits/nios21_1/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1/../../../../nios2-elf/bin/ld region sram_0 is full (simple_axiom_test.elf section .bss) simple_axiom_test line 0 ******************************************************** CODE: // test memory# include <stdio.h># include <stddef.h># include <unistd.h># include <fcntl.h># include <stdlib.h> # include "system.h" // generated header for the SOPC generated logic# include "io.h" // defines IORD, IOWR //#include "simple.h" # include "sys/alt_dev.h"# include "priv/alt_file.h"# include "alt_types.h" # include "sys/alt_sys_init.h" // contains reference to "alt_syst_init()" //#include "myboard.h" // file to put system.h into a easy to read header //#include "uart.h" // prototypes for the UART functions. //#define SRAM_MEM_SIZE 1048575 //0x000FFFFF;# define SRAM_MEM_SIZE 1024000 //0x000FFFFF; //#define SRAM_BASE_0 0x0080; volatile unsigned long MEMORY_READ; // ??? what is 32 bits long for altera types //unsigned long *SRAM_BASE_0; //unsigned long SRAM_BASE_0; //volatile unsigned long FAILED_ADDRESS; //volatile unsigned long REC_DATA; int main(void) { int i; int err_flag; static unsigned long MEMORY_ARRAY[SRAM_MEM_SIZE]; volatile unsigned long FAILED_ADDRESS; volatile unsigned long REC_DATA; printf("Hello from Nios II!\n"); err_flag = 0; //Fill SRAM Base Memory with all a's first for (i=0; i<SRAM_MEM_SIZE; i = i + 4) //Writes { //IOWR((unsigned long *)(SRAM_BASE_0), i ,0xAAAAAAAA); IOWR(0x00800000, i, 0xAAAAAAAA); } for (i=0; i<SRAM_MEM_SIZE; i = i + 4) { // Read MEMORY_READ = IORD(0x00800000, i ); // Store in an array MEMORY_ARRAY=memory_read;}
// if expected results match proceed otherwise set err_flag
// capture address that fails and break out of test
// set error flag to -1
for (i=0;i<sram_mem_size;i = i + 4)
if( memory_array != 0xAAAAAAAA) { err_flag = -1; REC_DATA = MEMORY_ARRAY;
failed_address = i;
//fill sram base memory with all 5's first
for (i=0; i<3; i++) // how do increase by 4
//writes
iowr(0x00800000, i ,0x55555555);
for (i=0; i<sram_mem_size; i = i + 4)
// read
memory_read = iord(0x00800000, i );
// store in an array
memory_array=MEMORY_READ; } // If expected results match proceed otherwise set err_flag // Capture Address that fails and break out of test // Set error flag to -1 for (i=0; i<SRAM_MEM_SIZE; i = i + 4) { if( MEMORY_ARRAY != 0x55555555)
err_flag = -2;
rec_data = memory_array; FAILED_ADDRESS = i; } } if ( err_flag < 0) { if( err_flag == -1) { printf(" Memory Test Failed @ Address = %x \n", FAILED_ADDRESS); printf(" Received data = %x \n", REC_DATA); printf(" Expected data = %x \n", 0xAAAAAAAA); } if( err_flag = -2) { printf(" Memory Test Failed @ Address = %x \n", FAILED_ADDRESS); printf(" Received data = %x \n", REC_DATA); printf(" Expected data = %x \n", 0x55555555); } else { printf("All Memory Tests PASSED!\n"); } } printf("End of Program \n"); return(0); }
Hi Ray,
You don't have enough space in your .sram_0 section: ># define SRAM_MEM_SIZE 1024000 ... > static unsigned long MEMORY_ARRAY[SRAM_MEM_SIZE] requires almost 4 MB in the output section. Other data, library code and app code gets added in as well (assuming everything is being placed in the SRAM). Regards, --Scott - Altera_Forum
-Ray
