21 years agoMemory -> DMA -> UART
Quartus 4.2 | NIOSII 1.1 | EP1S25 DSP-Board | Win2k
Hi there, i got the DMA working with HAL to send data from memory to memory. My next wish is to send data from memory to the UART. My UART receives 8bit, so i just tried to send one byte but it makes me a headache http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/blink.gif Why can´t i just set the destinationadress to the UART instead of another part of the memory? Has anyone experience with that? Do i have to implement a kind of sleep-function while sending data because of the lowspeed of the UART(9600bps)? Some ideas would be nice! Happy easter & nice egg-searching!4 Replies
int fdterm; // FILEDESCRIPTOR RETURNED BY OPEN
int i; // for for(); FILE * fpterm; // FILE pointer returned by fdopen int uart1_rxcount = 0; //counts received data from uart alt_u8 uart1_rxbuffer[5]; //stores received data from uart int pattern=0xF;//data to fill memory unsigned int *p = (unsigned int*)(0x00010000);//Startadress unsigned int *j = (unsigned int*)(0x00010100);//Destinationadress //DMA_BASE= 0x00020880 //UART_BASE = 0x00020820 int main(void) { //Write to memory something for (i=0; i<5; i++) { IOWR_32DIRECT(p/*+i*/, 0, pattern);//writes pattern from memory to memory+5 } //to open the uart-channel in read/write-modus // fdterm = open("/dev/uart1", O_RDWR | O_NONBLOCK | O_NOCTTY); // fpterm = fdopen(fdterm,"rw+"); // fprintf(fpterm,"UART1 STARTED\r\n"); // check initial output //printf("JTAG STARTED\r\n"); IOWR_ALTERA_AVALON_DMA_CONTROL(DMA_BASE, 0x0); // dma transfer disabled //Send some words IOWR_ALTERA_AVALON_DMA_STATUS(DMA_BASE, 0); IOWR_ALTERA_AVALON_DMA_RADDRESS(DMA_BASE, (int)p); //Pointer to memory IOWR_ALTERA_AVALON_DMA_WADDRESS(DMA_BASE, (int)j); //Pointer to your device IOWR_ALTERA_AVALON_DMA_LENGTH(DMA_BASE, 4); //Sending words (1 word == 4 bytes) IOWR_ALTERA_AVALON_DMA_CONTROL(DMA_BASE, 0x0CC); //See description of dma control register return 0; } This is the code which copies from p (memory) to j(memory). Why can´t i copy from p(memory) to j(uart)? I hope there is no huge thinking mistake http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif thanks for help! - Altera_Forum
According to the views, my problem seems to be too difficult or too easy...
Have you tried setting the WCON bit in the control register? The RCON and WCON bits in the DMA control register are for when you have constant read/write addresses. In your case, you have a constant write address: txdata of the UART.
I would also set the DMA to perform byte transfers only, but that's just me... Best of luck and I hope this helps! - slacker - Altera_Forum
thanks for your answer, i´m on it...
i´m also trying to use the small-driver-option for the preprocessor... the mode for the DMA was just a test, originally it was set on byte-transfer-only... Regards, Max
