15 years agoMegaWizard-generated memory with Nios II
I need a MegaWizard-generated on-chip memory to be the main memory for Nios II system.
How is it possible? How can I get a suitable memory interface in SOPC?5 Replies
in your SOPC builder, see Component Library.
[Library]->[Memories and Memory Controllers]->[On-Chip]->[On-Chip Memory(RAM or ROM)] and [Add] it. on chip memory may be small for NiosII in normal use. you should remove some functions from system property in NiosII EDS(eclips). - Altera_Forum
@akira:
I know how to add on-chip memory inside SOPC, what I need is to have one outside (in my top-level), as if it was external memory. The reason is that I need to be able to manipulate with memory data and address outside SOPC. - Altera_Forum
I don't think there is any way of adding memory with its second port signals exposed (this ought to be a standard block! [1]). So you'd have to write your own avalon slave that contains the memory block and exposes its signals.
The alternative (depending on what you are doing) it to use an avalon master - but that is harder. [1] Similarly memory blocks that are aliased into avalon address space, and blocks with missing high bits (eg 18 bit memory with the top bits read-zero). - Altera_Forum
I will try to be more specific (maybe this will help to come up with alternative solutions).
I need to make the on-chip memory (the only memory I have) protected with parity check. Say, if the memory is 32 bit then on every write access I want to write 33 bit word consisting of data and parity. And on every read access to calculate parity again and to compare it with the parity bit. I have easily build the memory I need with MegaWizard, and made some wrapper blocks for parity check on read and write, now I don't know how to make so that my Nios II system use this memory. - Altera_Forum
do you know how to create custom-IP core.
as dsl told you, you can create that part "inside" of SOPC builder. it is able to access from outside of SOPC builder via conduit out port.
