10 years agoMAX10M08 Flash Accelerator
Hi, I am working on a project using the MAX10M08 with Nios ii /f and Quartus Prime Lite 15.1.2. Up to now i used the onchipmemory as instruction memory. But the goal is run from the onchi...
10 years agoSystem looks ok. Connections/resets are proper. Simulation on the system is ok too. Side note is that onchip-memory is not aligned to byte or 32768.
Probably you should check with Altera AE for further debug. For now, maybe you can try to workaround by using 128 bit line size.
