10 years agoMAX10M08 Flash Accelerator
Hi, I am working on a project using the MAX10M08 with Nios ii /f and Quartus Prime Lite 15.1.2. Up to now i used the onchipmemory as instruction memory. But the goal is run from the onchi...
10 years agoI programmed the flash using the "convert programming files" method, merging the sof and the flash.hex (make mem_init_generate) and programmed the pof with the quartus programmer.
There is one thing to note: I don't have a licence for the /f core yet, so i can not merge the timelimited sof. Therefore i merge a non timelimited sof (empty project) with the hex and flash only the UFM and not the CFM. After that i configure the device with the timelimited sof. I hope this shouldn't be the problem? Ok that is right the data slave must be connected to the data master of the nios. Strange that the verify was successful. So i tested this. I kept the data slave unconnected, built two different programs (program1 and program2) flashed the hex of program1 and verified against elf of program2. nios-download always says Verified OK. With connected data slave, i get a Verify missmatch as expected.
Downloaded 20KB in 0.3s (66.6KB/s)
Verifying 00020000 ( 0%)
Verify failed between address 0x20000 and 0x24EF7
Leaving target processor paused
0x20000 is the reset address and baseaddress of the flash. Verify against program1 elf succeeds as expected, so i think the flash content is correct. For testing without debugger i added a PIO component to toggle a LED in a loop with alt_busy_sleep. I used "nios-download --reset-target --go" to reset and start the processor without debugging. - The led does not blink with cachelinesize set to 64 bit. => core stuck?
- Using cachelinesize set to 128 bit the LED starts blinking.
