10 years agoMAX10M08 Flash Accelerator
Hi, I am working on a project using the MAX10M08 with Nios ii /f and Quartus Prime Lite 15.1.2. Up to now i used the onchipmemory as instruction memory. But the goal is run from the onchi...
10 years agoHow did you load the onchip-flash content? I don't think nios2-download can verify the flash content since you did not connect the Nios data master to the onchip-flash.data.
Can your application run correctly? Or is this just a debug session issue?
