tsuto's avatar
tsuto
6 years ago
MAX10 Nios2/f and dual-port RAM
I implemented some of the M9K memory blocks in Nios2 as dual port RAM for exchanging data with the outside. Both memory width is 16bit. There was no problem when using Nios2/e as the CPU, but after...
  • tsuto's avatar
    6 years ago
    If the CPU cache memory is disabled, the value written in the dual port RAM can be read.
    Specifically, in Qsys, all of Instruction Cache, Flash Accelerator, and Data Cache in the Caches and Memory Interface tab of Nios2 Processor are set to NON. It may be fine to disable only the Data Cache, but since I achieved the purpose, I have not checked with other enabled.
