15 years agoMax throughput of SOPC DMA?
Hello, Currently I have a system with DMA transfers and DDR2 SDRAM (and a lot of other stuff). I'm using the normal SOPC builder DMA controller. I run the system on 100 MHz, the DDR2 SDRAM run...
15 years agoIf I only add one (since the buffer is able to store 128 descriptors):
while ((read_csr_status(MODULAR_SGDMA_ONCHIP_CSR_BASE) & CSR_DESCRIPTOR_BUFFER_FULL_MASK) != 0) {} and then 128 times write_standard_descriptor (MODULAR_SGDMA_ONCHIP_CSR_BASE, MODULAR_SGDMA_ONCHIP_DESCRIPTOR_SLAVE_BASE, a_descriptor_ptr) ; in the for loop. I get a maximum throughput of 3760MB/s (did a miscalculation earlier). The data does seem to get transfered though, if in the middle of those 128 'write_standard_descriptors' I clear the RX memory and after one 'write_standard_descriptor' I read it back out again. Edit: Something still goes wrong with calculation, since when I double the transfer_size, the number of clock_ticks double but the transfer size decreases. Edit2: I'm running towards the maximum I can store in an unsigned long I think >,<. Edit3: Yup, was going over 2^32. Edit4: Calculating gives: Test completed with a transfer size of 40000MB Transfer time (clocks ticks): 83374115 Transfer time (seconds): 0.833741 This gives a throughput of 47962MB/s which means with a clock of 100 mhz a throughput of 47962 mb/s , now that can't be right or can it? Edit5: Ah if I wrap an IF around it
if(write_standard_descriptor (MODULAR_SGDMA_ONCHIP_CSR_BASE, MODULAR_SGDMA_ONCHIP_DESCRIPTOR_SLAVE_BASE, a_descriptor_ptr) != 0)
printf("Failed to write descriptor 0x%lx to the descriptor SGDMA port.%c", i+1, TERMINAL_KILL_CHARACTER);
I get Failed to write descriptor 0x42 to the descriptor SGD. I have to add
while ((RD_CSR_STATUS(MODULAR_SGDMA_ONCHIP_CSR_BASE) & CSR_DESCRIPTOR_BUFFER_FULL_MASK) != 0) {} // spin until there is room for another descriptor to be written to the SGDMA
between each write_standard_descriptor .
