15 years agoMax throughput of SOPC DMA?
Hello, Currently I have a system with DMA transfers and DDR2 SDRAM (and a lot of other stuff). I'm using the normal SOPC builder DMA controller. I run the system on 100 MHz, the DDR2 SDRAM run...
15 years agoFirst thing in the for loop is:
while ((read_csr_status(MODULAR_SGDMA_ONCHIP_CSR_BASE) & CSR_DESCRIPTOR_BUFFER_FULL_MASK) != 0) {} // spin until there is room for another descriptor to be written to the SGDMAThen the code in the for loop is ~13 times the code below (nasty I know :)):
write_standard_descriptor (MODULAR_SGDMA_ONCHIP_CSR_BASE, MODULAR_SGDMA_ONCHIP_DESCRIPTOR_SLAVE_BASE, a_descriptor_ptr) ;
So I have 128 (descriptors which is the max FIFO at the moment times) of these in a row: write_standard_descriptor (MODULAR_SGDMA_ONCHIP_CSR_BASE, MODULAR_SGDMA_ONCHIP_DESCRIPTOR_SLAVE_BASE, a_descriptor_ptr) ; The length for each descriptor is 16384 bytes and I do the whole thing 100 times. i was wondering if this way i do in fact transfer 128*100*16384 bytes? Since I'm getting a maximum transfer rate of 3380MB/s between the 2 on-chip memories and that's pretty neat. (To a maximum of throughput of 3770MB/s if I increase the number of transfers.) I know it works if I add only one: write_standard_descriptor (MODULAR_SGDMA_ONCHIP_CSR_BASE, MODULAR_SGDMA_ONCHIP_DESCRIPTOR_SLAVE_BASE, a_descriptor_ptr) ; and I can make the length whatever I want (and see that happening). but does adding 128 of these mean a transfer size of 128*length? I think it does, but I might be overlooking something. What I now have are 2 on-chip memories of each 32kb and I continually write 16k between them (so I keep overwriting the RX data). Edit: I guess I could just clear the RX memories between writes and see if it it filled after a next descriptor write.
