15 years agoMax throughput of SOPC DMA?
Hello, Currently I have a system with DMA transfers and DDR2 SDRAM (and a lot of other stuff). I'm using the normal SOPC builder DMA controller. I run the system on 100 MHz, the DDR2 SDRAM run...
15 years agoI enabled burst transfers now. The clock crossing bridge only supports 256 words (the FIFO can't be any bigger) and for the on-chip memory it can be a maximum of 1024 words. I got the following results, which already is a big improvement. It's about a factor 8 with the on-chip memory. Which would make sense, like you said Daixiwen, if the Serial RapidIO now makes packages of 256 bytes data (the max) in stead of 32 bytes.
I think the reason that burst transfers didn't work the last time I tried it, is that I didn't enable it for the clock crossing bridge :rolleyes:. These times are for a write transaction and after that a read transaction. So for throughput of the DMA controller you can double the number. I used a for loop to perform the multiple transactions. two on chip memories Number of words in hexadecimal format (max 0x2000)...0x400 How many transactions? In decimal format...50000 0x400 * 50000 = 51200000 words = 204800000 bytes = 195.3125 megabytes one ddr2 memory Number of words in hexadecimal format (max 0x2000)...0x100 How many transactions? In decimal format...200000 0x100 * 200000 = 51200000 words = 204800000 bytes = 195.3125 megabytes +---------------+-----+-----------+---------------+-----------+ | Section | % | Time (sec)| Time (clocks)|Occurrences| +---------------+-----+-----------+---------------+-----------+ |DDR2 DMA | 8.17| 8.27889| 827888631| 1| +---------------+-----+-----------+---------------+-----------+ |On-chip DMA | 2.76| 2.79213| 279212507| 1| +---------------+-----+-----------+---------------+----------- Transfer speed DDR2: 195.3125 / 8.27889= 23.59 megabyte/second Transfer speed on-chip DMA: 195.3125 / 2.79213= 69.95 megabyte/second The set-up times aren't that big, by which I mean: alt_dma_txchan_send (txchan, tx_data, length, null, null); alt_dma_rxchan_prepare (rxchan, rx_data, length, txrxDone, null); +---------------+-----+-----------+---------------+-----------+ | Section | % | Time (sec)| Time (clocks)|Occurrences| +---------------+-----+-----------+---------------+-----------+ |Write set-up |0.429| 0.12740| 12740253| 20000| +---------------+-----+-----------+---------------+-----------+ |Read set-up | 0.43| 0.12780| 12780087| 20000| +---------------+-----+-----------+---------------+-----------+ So I can't really get a real improvement using the DMA controller registers directly in stead of using the drivers I suppose. Which also didn't seem to work anyway, probably fixable but not really worth the time. question here :): so i guess it's time for the scatter-gather dma controller. do you getting that getting that to work is doable in like 60 to 80 hours? it doesn't seem to be to difficult if i look at the data sheet or i.e. this thread : http://www.alteraforum.com/forum/showthread.php?t=21462&highlight=sgdma (http://www.alteraforum.com/forum/showthread.php?t=21462&highlight=sgdma) or this example http://www.nioswiki.com/exampledesigns/sgdma (http://www.nioswiki.com/exampledesigns/sgdma), but you never know -,-. Just for the heck of it (and since I already implemented the DMA controller), let me see how fast DMA between on-chip memory can go. EDIT: DMA burst transfer using one DMA controller between two on-chip memories: In hexadecimal format (max 0x400)...0x400 How many transactions? In decimal format...50000 --Performance Counter Report-- Total Time: 11.1866 seconds (1118663570 clock-cycles) +---------------+-----+-----------+---------------+-----------+ | Section | % | Time (sec)| Time (clocks)|Occurrences| +---------------+-----+-----------+---------------+-----------+ |On-chip DMA | 21.1| 2.36401| 236400523| 1| +---------------+-----+-----------+---------------+-----------+ Transfer speed: 195.3125 / 2.36401= 82.619 megabyte/second (So per DMA transfer about 82.619*2 = 165,238 megabyte/second.) With the following code:
/*Open DMA channels */
PERF_BEGIN (PERFORMANCE_COUNTER_BASE, SECTION_TO_MONITOR_2); //Start timing section
for (i=0;i<number_of_transactions;i++)
txrx_done_w=0;
txrx_done_r=0;
alt_dma_txchan_send (txchan_w, tx_data_w, length, NULL, NULL);
alt_dma_rxchan_prepare (rxchan_w, rx_data_w, length, txrxDone_w, NULL);
while (!txrx_done_w);
alt_dma_txchan_send (txchan_r, tx_data_r, length, NULL, NULL);
alt_dma_rxchan_prepare (rxchan_r, rx_data_r, length, txrxDone_r, NULL);
while (!txrx_done_r);
PERF_END (PERFORMANCE_COUNTER_BASE, SECTION_TO_MONITOR_2); //End timing section
/* Close channels */
