9 years agoMax 10 ADC: Nios stuck at endless loop in alt_irq_handler()
Hi
I'm trying to get ADC to run with Deca Max 10 Evaluation board. When debugging the program in Nios, it appears to get stuck in the alt_irq_handler() function.
active = alt_irq_pending ();
do
i = 0;
mask = 1;
* Test each bit in turn looking for an active interrupt. Once one is
* found, the interrupt handler asigned by a call to alt_irq_register() is
* called to clear the interrupt condition.
do
if (active & mask)
{ # ifdef ALT_ENHANCED_INTERRUPT_API_PRESENT
alt_irq.handler(alt_irq.context); # else
alt_irq.handler(alt_irq.context, i); # endif
break;
mask <<= 1;
i++;
} while (1);
} while (active);# endif /* ALT_CI_INTERRUPT_VECTOR */ I have no clue why it's stuck here???? Following is my simple code for reading ADC in main() function and attached file is the Qsys configuration.
int count = 0;
alt_u32 adc_data;
/* Initialize adc */
adc_stop(ADC_SEQUENCER_CSR_BASE);
adc_interrupt_disable(ADC_SEQUENCER_CSR_BASE); // Disable interrupt
adc_clear_interrupt_status(ADC_SEQUENCER_CSR_BASE);
adc_set_mode_run_continuously(ADC_SEQUENCER_CSR_BASE); // Set ADC run mode
adc_start(ADC_SEQUENCER_CSR_BASE); // start sampling
for(alt_u32 sampleCnt=0; sampleCnt<100; sampleCnt++) // read 1000 samples
alt_adc_word_read(ADC_SAMPLE_STORE_CSR_BASE, adc_data, ADC_SAMPLE_STORE_CSR_CSD_LENGTH);
count++;
adc_stop(ADC_SEQUENCER_CSR_BASE); // Stop ADC sampling
while (1);
Any help would be really appreciated. Thankshttps://alteraforum.com/forum/attachment.php?attachmentid=13911&stc=1No RepliesBe the first to reply
