10 years agomalloc problem
Hello I am using Quarts and Nios 9.1 versions. In my board I have external (altmemddr) and on-chip (inside Cyclone III) memory. In the system library properties all memory (including rwdata...
10 years agoThe increase in code size is likely due to the .cinit to initialize the data.
Instead of doing it this way, just do it with a pointer and a linker region: modify your linker script to create a region to hold your "CisSheetQueue" and then:
unsigned char *pCisSheetQueue = (unsigned char *)the_address_of_the_region_you_just_created;
If I recall, you can manage the linker script regions through the BSP editor.
