14 years agomaking an IP for DMA transfers
Hello everybody. I work with the Terasic DE2-115. I'm trying to plug the TRDB-D5M camera on a NIOS II with ethernet. I can read data from the camera with the IP given by terasic, and I can us...
14 years agoThe Qsys OnChip FIFO interface is ready, valid, and data[31..0]
Planning to connect Qsys:ready--> DCFIFO:rdreq and DCFIFO:empty --> NOT--> Qsys:valid That seems to work using a DCFIFO --> SCFIFO test design. Assumptions based on documentation that OnChip FIFO implements an SCFIFO for single clock option. I attended a Qsys workshop a couple of months ago and have a copy of mSGDMA (from PCIe example) in the files ... so installed a write master and dispatcher hooked up with ST export. Sure enough got the same 3 ... ready, valid, and data[31..0]
