15 years ago(make vendor_hwselect SYSPTF ERROR) Perl hwselect.pl when compile uclinux kernel
I never met this before. succeed in uClinux2007,uClinux2009.But crashed in uClinux2010* . root@spomu-desktop:/home/work/uClinux-dist201010# make vendor_hwselect SYSPTF="/home/work/niosII.ptf...
15 years agoHi,
seems that you didn't choose the right branch for it. if you use the noMMU version the output ofgit branch should be that test-nios2 is selected. so this must be selected in the 'uClinux-dist' as well as in the 'linux2.6' folder. I don't know if the noMMU also works with the "trunk"-branch from "nios2 linux distribution". Even if this is possible the command make vendor_hwselect is not used in the "new" distribution. Urmel
