10 years agoMAC Address Change Buggy
Hi, I encounted a problem I had to commit I could not solve on my own: platform: Altera / Quartus FPGA with TSE (triple-speed ethernet) with Altera drivers which are supported by uCLinux. pro...
10 years agoHi,
--- Quote Start --- it fails before and after, means clearing the ARP cache is no solutiuon. But funny is: I CAN ping the host from the host itself! --- Quote End --- I recommend you to use a packet analyzer like 'WireShark' https://www.wireshark.org/ and check the ether packet header whether it has the new Mac number or not. If it has your correct new address, I recommend you to check your phy chip. (Generally, ping packets which are sent to itself will not use physical layer.) Kazu
