20 years agoLWIP question regarding speed optimization
when fooling around with the performance counter inside the LWIP checksum routines, i discovered that in the LWIP_checksum routine, the actual making of the checksum is 10% of the load, the reaming 90% is cedited to the return stament at the end, totalling over 50000 clock cycles for returning a value...
does returning the value really take this long? i dont understand this, if this is correct then using HW to do the checksumming would give me less then 10% increase (i cant go from 15 clock cycles to 0 for the checksum operation after all, it will still be 5 cycles or so) so where do those 50000 cycles go every checksum? when my webserver is outputting data then 100% of the cpu load is in the LWIP_Checksum routine, 10 on the calculations, 90 on the return does anyone have a clue?2 Replies
--- Quote Start --- originally posted by thomsonbro+oct 20 2005, 08:54 am--><div class='quotetop'>quote (thomsonbro @ oct 20 2005, 08:54 am)</div>--- quote start ---
when fooling around with the performance counter inside the lwip checksum routines, i discovered that in the lwip_checksum routine, the actual making of the checksum is 10% of the load, the reaming 90% is cedited to the return stament at the end, totalling over 50000 clock cycles for returning a value...[/b]
--- quote end ---
wow. that does look funny, but i have to wonder if it's crediting loop-control time to that return statement, or more likely, if it's doing a lot of restore-calling-state-before-return work. or maybe you're getting interrupted there?
<!--quotebegin-thomsonbro@Oct 20 2005, 08:54 AM does returning the value really take this long? i dont understand this, if this is correct then using hw to do the checksumming would give me less then 10% increase (i cant go from 15 clock cycles to 0 for the checksum operation after all, it will still be 5 cycles or so) --- Quote End --- Sounds like you just need to replace the whole function call with a custom instruction or macro...?
to be honest i think your right, i think the performance counter is including the cpu time for the underlying routines that called the checksum routine to the return statement, i see no other way realy
now to find out were all that stuff actually goes http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
