VRama10
7 years agoLVDS error in 18.1 while using Triple Speed Ethernet IP
Hi, I'm a beginner with Nios II platform designer. I was using an example project from Intel built for Cyclone 10 GX board using Quartus 17.1. It was working fine. As I need to integrate this des...
YHäri
7 years agoHi,
we are experiencing the same issue with the Cyclone 10GX evaluation board. If I understood correctly this seems to be a hardware bug of the evaluation board, as there is no LVDS clock connected to the bank 2L where the Ethernet Core is connected to?
The clock "C10_REFCLK1p" (n) which is used in the simple socket example uses another bank and the clock "C10_REFCLK2p" (n) is connected to pins G23 & F23, which don't support LVDS.
According to the following post, the LVDS SERDES IP requires a LVDS clock on the same bank.
Best Regards
