Looking for HPS to FPGA custom component integrations guideline using Qsys
I am looking for HPS to FPGA custom component integrations guideline using Qsys. I am new to SoC FPGA programming. I still could not found a material or tutorial for HPS to custom VHDL or Verilog component integration. I need to get to know what are the connections that I should make and how to/ where to declare them in C code on ARM processor and the entity of the FPGA custom designed component. Can any body post some links.
I have read following tutorials. Avalon Interface Specifications pdf ARM_A9_intro_intelfpga pdf Intel_FPGA_Monitor_Program_ARM pdf making qsys component pdf Using_GIC - ARM HPS pdf External_Bus_to_Avalon_Bridge -nios II pdf Avalon_to_External_Bus_Bridge nios II pdf DE0-Nano-SoC_Computer_ARM pdf9 Replies
I am also looking for interfacing custom component to HPS. Did you manage to find out the solutions? If yes, I request you to provide the links for the documents.
Thank you. - Altera_Forum
The custom component is quite easy. Did you try to create a custom component and send/receive data with it using NIOS? It should be similar but with small modifications.
Thank you for your reply. I have not tried using NIOS. But I have seen some documents describing the same. Could you please share a document which gives detailed step by step instruction? I have gone through the tutorials on Altera and Rocketboards. These tutorials/workshops use ready made templates. These do not explain every step. I am looking for a document/tutorial/link which gives step by step for every setting.
Thank you. Regards - Altera_Forum
You should try this
ftp://ftp.altera.com/up/pub/altera_material/15.1/tutorials/making_qsys_components.pdf I also suggest you start with nios (using eclpise) to communicate with your new custom component. - Altera_Forum
Thank you for sharing the document. I have already used that tutorial. In that tutorial Avalon memory map is used. In my system I am using ARM processor instead of NIOS. I am not sure whether I can interface my custom peripheral using Avalon memory map in the case ARM. I have come across posts saying interconnect bridges can solve this. But didn't find a document on that.
--- Quote Start --- Thank you for sharing the document. I have already used that tutorial. In that tutorial Avalon memory map is used. In my system I am using ARM processor instead of NIOS. I am not sure whether I can interface my custom peripheral using Avalon memory map in the case ARM. I have come across posts saying interconnect bridges can solve this. But didn't find a document on that. --- Quote End --- Yes the QSYS will connect the peripherals correctly, both AXI and Avalon. I already tried it and it works. On ARM C coding, you will need a pointer that targets the address of that custom peripheral (with lightweight offset. Check the tutorials). Did you try to use the ARM with gpio or any pre-built peripheral from the QSYS tool? - Altera_Forum
Thanks for your reply!
I am going through training courses provided at Altera website (https://www.altera.com/support/training/catalog.html?coursetype=online&language=english&keywords=arm). Hopefully these courses contain information about HPS system creation and using it in DS-5 tool. Yet I am not successful in using ARM system with a peripheral. While saying about C coding and pointer, you referred to check tutorials. Could you please let me know their location? - Altera_Forum
Check the following tutorial
https://www.altera.com/support/support-resources/design-examples/soc/fpga-to-hps-bridges-design-example.html and the following page https://www.altera.com/support/support-resources/design-examples.html It was not easy for me to start using the ARM HPS. I spent hours trying to understand how to program it and the tutorials which I gave you its links were not very good but may help you. They are not really tutorials but example projects with the codes. But I already have experience with NIOS which help a lot start using the HPS. I also have better experience using Xilinx Zynq. This also helped me. - Altera_Forum
Thank you sir for the tutorial and link. I have experience in dealing with Xilinx Zynq and other boards. Use of Arria V SoC kit is my first encounter with Altera devices. I feel my inexperience with Altera devices and the Altera SoC design flow, which is altogether different from the flow I followed for Xilinx devices, are complicating my learning.
I have been through many tutorials, videos and links of Altera SoC designs. Altera has compiled many good examples and projects at Altera training and Rocketboards websites. Personally for a beginner like me these are advanced in nature. I will follow the material you have provided and will share my experience.
