12 years agoLoading executable files to SD card
I am following the instructions in the My_First_HPF.pdf that comes with the CD for the DE1-SoC under Demonstrations. In it, it says to load the executable onto an SD card using an ethernet router an...
11 years agoWhat are you trying to do? The device is a standard network device, with an IP address, so just like any other device you can log in to it like a computer.
According to the website information, the DE1-SoC has a micro SD card slot, so if you have a micro SD card and set the correct BOOTSEL and MSEL settings you should be able to load whatever you want without needing a network. Otherwise, if the SD card is mounted on the embedded Linux, then you should be able to copy files over.
