15 years ago[Linux/MMU] net-snmp AgentX activation problem
Hi All, I need SNMP with masterX support for my project, but I cannot turn AgentX master support on. I have added 'master agentX' in snmpd.conf, but I get a 'Warning: Unknown token: master' when ...
15 years agoHum, I re-read my answer and can see a typo error : I wanted to write 'This (and not 'The') should be true if CONFIG_...'.
In other words, you *must* unselect 'Build mini agent' if you want the AgentX functionality - in my configuration, 'net-snmp' is the only option selected) -, and you have *not* to modify the top Makefile. For the other questions (how i use agentx???? which basics commands???? ), I'm following the Net-Snmp tutorials and discover this new (for me) world... Good luck, Fred
