17 years agoLinux with MMU on NEEK
Hi, all. I'm testing Linux MMU version, on my NEEK. http://www.nioswiki.com/linux It works fine and I can use "bash" shell. This is the evident proof that we are using the true 'fo...
16 years agoHi,
The previous version of 'kgdb' will not read the Nios's registers r17~r23. http://www.alteraforum.com/forum/showpost.php?p=77003&postcount=20 But the kernel sometimes uses those for the locations of its local variables, so we must read and write the registers r17~r23. To do this, please add codes to the file 'entry.S'
handle_diverror:
call handle_illegal_c
br ret_from_exception
# ifdef CONFIG_KGDB
handle_kgdb_breakpoint:
SAVE_SWITCH_STACK // <-- Add this.
call kgdb_breakpoint_c
RESTORE_SWITCH_STACK // <-- Add this.
br ret_from_exception# endif
and modify the file 'kgdb.c' of the nios arch like
void pt_regs_to_gdb_regs(unsigned long *gdb_regs, struct pt_regs *regs)
gdb_regs = 0;
gdb_regs = regs->r1;
gdb_regs = regs->r2;
gdb_regs = regs->r3;
gdb_regs = regs->r4;
gdb_regs = regs->r5;
gdb_regs = regs->r6;
gdb_regs = regs->r7;
gdb_regs = regs->r8;
gdb_regs = regs->r9;
gdb_regs = regs->r10;
gdb_regs = regs->r11;
gdb_regs = regs->r12;
gdb_regs = regs->r13;
gdb_regs = regs->r14;
gdb_regs = regs->r15;
gdb_regs = regs->ra;
gdb_regs = regs->fp;
gdb_regs = regs->sp;
gdb_regs = regs->gp;
gdb_regs = regs->estatus;
gdb_regs = regs->ea;
struct switch_stack *swregs = (struct switch_stack *)regs;
swregs--;
gdb_regs = swregs->r16;
gdb_regs = swregs->r17;
gdb_regs = swregs->r18;
gdb_regs = swregs->r19;
gdb_regs = swregs->r20;
gdb_regs = swregs->r21;
gdb_regs = swregs->r22;
gdb_regs = swregs->r23;
void gdb_regs_to_pt_regs(unsigned long *gdb_regs, struct pt_regs *regs)
regs->r1 = gdb_regs;
regs->r2 = gdb_regs;
regs->r3 = gdb_regs;
regs->r4 = gdb_regs;
regs->r5 = gdb_regs;
regs->r6 = gdb_regs;
regs->r7 = gdb_regs;
regs->r8 = gdb_regs;
regs->r9 = gdb_regs;
regs->r10 = gdb_regs;
regs->r11 = gdb_regs;
regs->r12 = gdb_regs;
regs->r13 = gdb_regs;
regs->r14 = gdb_regs;
regs->r15 = gdb_regs;
regs->ra = gdb_regs;
regs->fp = gdb_regs;
regs->sp = gdb_regs;
regs->gp = gdb_regs;
regs->estatus = gdb_regs;
regs->ea = gdb_regs;
swregs--;
swregs->r16 = gdb_regs;
swregs->r17 = gdb_regs;
swregs->r18 = gdb_regs;
swregs->r19 = gdb_regs;
swregs->r20 = gdb_regs;
swregs->r21 = gdb_regs;
swregs->r22 = gdb_regs;
swregs->r23 = gdb_regs;
. Kazu
