17 years agoLinux with MMU on NEEK
Hi, all. I'm testing Linux MMU version, on my NEEK. http://www.nioswiki.com/linux It works fine and I can use "bash" shell. This is the evident proof that we are using the true 'fo...
16 years agoHi, Kazu
Thank you for your response, the problem has been solved by your advice. But the new confusion was that nothing appeared on the screen and Nano-X seemed running correctly:
/# nano-X &
686 nano-X
/# nanowm &
687 nanowm
/# nxclock &
688 nxclock
And the linux init messages is below
$ nios2-terminal
nios2-terminal: connected to hardware target using JTAG UART on cable
nios2-terminal: "USB-Blaster ", device 1, instance 1
nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate)
Linux version 2.6.30-00494-g84a224b-dirty (alex@alex-desktop) (gcc version 4.1.2)# 38 Thu Aug 12 16:36:39 CST 2010
console enabled
Early printk initialized
Linux/Nios II-MMU
init_bootmem_node(?,0x50c, 0x0, 0x2000)
free_bootmem(0x50c000, 0x1af4000)
reserve_bootmem(0x50c000, 0x400)
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 8128
Kernel command line:
NR_IRQS:32
PID hash table entries: 128 (order: 7, 512 bytes)
Console: colour dummy device 80x25
Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
We have 8192 pages of RAM
Memory available: 27300k/5165k RAM, 0k/0k ROM (1577k kernel code, 3588k data)
Calibrating delay loop... 49.25 BogoMIPS (lpj=246272)
Mount-cache hash table entries: 512
net_namespace: 296 bytes
NET: Registered protocol family 16
init_BSP(): registering device resources
bio: create slab <bio-0> at 0
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 1024 (order: 1, 8192 bytes)
TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
TCP: Hash tables configured (established 1024 bind 1024)
TCP reno registered
msgmni has been set to 53
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered (default)
fb0: Altera FB frame buffer device
ttyJ0 at MMIO 0x8001410 (irq = 7) is a Altera JTAG UART
console handover: boot -> real
altps2 : base e8001420 irq 9
mice: PS/2 mouse device common for all mice
TCP cubic registered
NET: Registered protocol family 17
atkbd.c: keyboard reset failed on altps2.0
Welcome to
____ _ _
/ __| ||_|
_ _| | | | _ ____ _ _ _ _
| | | | | | || | _ \| | | |\ \/ /
| |_| | |__| || | | | | |_| |/
| ___\____|_||_|_| |_|\____|\_/\_/
|_|
For further information check:
http://www.uclinux.org/
BusyBox v1.15.1 (2010-08-12 16:35:17 CST) hush - the humble shell
Enter 'help' for a list of built-in commands.
please give me some advices when your are free, and thank you again. --Smarter.UJS
