17 years agoLinux with MMU on NEEK
Hi, all. I'm testing Linux MMU version, on my NEEK. http://www.nioswiki.com/linux It works fine and I can use "bash" shell. This is the evident proof that we are using the true 'fo...
16 years agoHi,
Now, I'm trying to implement the relocating codes to the Nios's dynamic linker. At first, I must make the 'static' linker ' nios2-wrs-linux-gnu-ld' or 'ld' put relocating information. So I added some codes for two functions 'nios2_elf32_relocate_section' and 'nios2_elf32_check_relocs' in the file '/nios2gcc4/src/binutils-2.17.50/bfd/elf32-nios2.c'. About the details, please refer the attached file. With these 'static' linkers, we can compile the 'Samples', main.c, a.c and b.c as follows
nios2-wrs-linux-gnu-gcc -g -shared -Wl,-Bsymbolic -G0 a.c -o a.so
nios2-wrs-linux-gnu-gcc -g -shared -Wl,-Bsymbolic -G0 b.c -o b.so
nios2-wrs-linux-gnu-gcc -g main.c a.so b.so -o main
The relocation information of shared libraries are as follows. In 'a.readelf'
Relocation section '.rela.dyn' at offset 0x308 contains 18 entries:
Offset Info Type Sym.Value Sym. Name + Addend
00001834 00000027 R_NIOS2_RELATIVE 00001748
00001838 00000027 R_NIOS2_RELATIVE 00001864
0000183c 00000027 R_NIOS2_RELATIVE 00001860
00001840 00000027 R_NIOS2_RELATIVE 000004b0
00001844 00000027 R_NIOS2_RELATIVE 0000056c
00001848 00000027 R_NIOS2_RELATIVE 0000173c
0000184c 00000027 R_NIOS2_RELATIVE 0000062c
00001854 00000027 R_NIOS2_RELATIVE 0000185c
0000185c 00000027 R_NIOS2_RELATIVE 0000185c
00001860 00000027 R_NIOS2_RELATIVE 00001744
000005f4 00001104 R_NIOS2_CALL26 00000000 func_b + 0
00000614 00001104 R_NIOS2_CALL26 00000000 func_b + 0
000005fc 0000100b R_NIOS2_HIADJ16 00000000 j + 0
00000600 0000100a R_NIOS2_LO16 00000000 j + 0
00000608 0000100b R_NIOS2_HIADJ16 00000000 j + 0
0000060c 0000100a R_NIOS2_LO16 00000000 j + 0
00001850 00000b25 R_NIOS2_GLOB_DAT 00000000 _Jv_RegisterClasses + 0
00001858 00000f25 R_NIOS2_GLOB_DAT 00000000 __cxa_finalize + 0
Relocation section '.rela.plt' at offset 0x3e0 contains 2 entries:
0000182c 00000f26 R_NIOS2_JUMP_SLOT 00000000 __cxa_finalize + 0
00001830 00001126 R_NIOS2_JUMP_SLOT 00000000 func_b + 0
There are no unwind sections in this file.
Symbol table '.dynsym' contains 21 entries:
Num: Value Size Type Bind Vis Ndx Name
0: 00000000 0 NOTYPE LOCAL DEFAULT UND
1: 000003f8 0 SECTION LOCAL DEFAULT 8
2: 000004b0 0 SECTION LOCAL DEFAULT 10
3: 000006bc 0 SECTION LOCAL DEFAULT 11
4: 00000734 0 SECTION LOCAL DEFAULT 12
5: 00001738 0 SECTION LOCAL DEFAULT 13
6: 00001740 0 SECTION LOCAL DEFAULT 14
7: 00001748 0 SECTION LOCAL DEFAULT 15
8: 0000185c 0 SECTION LOCAL DEFAULT 18
9: 00001864 0 SECTION LOCAL DEFAULT 19
10: 000005dc 80 FUNC GLOBAL DEFAULT 10 func_a
11: 00000000 0 NOTYPE WEAK DEFAULT UND _Jv_RegisterClasses
12: 000006bc 0 NOTYPE GLOBAL DEFAULT 11 _fini
13: 00009810 0 NOTYPE GLOBAL DEFAULT ABS _gp
14: 00001864 0 NOTYPE GLOBAL DEFAULT ABS __bss_start
15: 00000000 356 FUNC WEAK DEFAULT UND __cxa_finalize@GLIBC_2.10 (2)
16: 00000000 0 NOTYPE GLOBAL DEFAULT UND j
17: 00000000 0 NOTYPE GLOBAL DEFAULT UND func_b
18: 00001868 0 NOTYPE GLOBAL DEFAULT ABS _end
19: 00001864 0 NOTYPE GLOBAL DEFAULT ABS _edata
20: 000003f8 0 NOTYPE GLOBAL DEFAULT 8 _init
. In 'b.readelf'
Relocation section '.rela.dyn' at offset 0x300 contains 17 entries:
00001850 00000027 R_NIOS2_RELATIVE 0000175c
00001854 00000027 R_NIOS2_RELATIVE 00001880
00001858 00000027 R_NIOS2_RELATIVE 0000187c
0000185c 00000027 R_NIOS2_RELATIVE 00000484
00001860 00000027 R_NIOS2_RELATIVE 00000540
00001864 00000027 R_NIOS2_RELATIVE 00001750
00001868 00000027 R_NIOS2_RELATIVE 00000640
00001870 00000027 R_NIOS2_RELATIVE 00001878
00001878 00000027 R_NIOS2_RELATIVE 00001878
0000187c 00000027 R_NIOS2_RELATIVE 00001758
000005f8 00000004 R_NIOS2_CALL26 000005b0
00000600 0000000b R_NIOS2_HIADJ16 00001830
00000604 0000000a R_NIOS2_LO16 00001830
00000618 0000000b R_NIOS2_HIADJ16 00001830
0000061c 0000000a R_NIOS2_LO16 00001830
0000186c 00000b25 R_NIOS2_GLOB_DAT 00000000 _Jv_RegisterClasses + 0
00001874 00000f25 R_NIOS2_GLOB_DAT 00000000 __cxa_finalize + 0
Relocation section '.rela.plt' at offset 0x3cc contains 1 entries:
0000184c 00000f26 R_NIOS2_JUMP_SLOT 00000000 __cxa_finalize + 0
1: 000003d8 0 SECTION LOCAL DEFAULT 8
2: 00000484 0 SECTION LOCAL DEFAULT 10
3: 000006d0 0 SECTION LOCAL DEFAULT 11
4: 00000748 0 SECTION LOCAL DEFAULT 12
5: 0000174c 0 SECTION LOCAL DEFAULT 13
6: 00001754 0 SECTION LOCAL DEFAULT 14
7: 0000175c 0 SECTION LOCAL DEFAULT 15
8: 00001830 0 SECTION LOCAL DEFAULT 17
9: 00001878 0 SECTION LOCAL DEFAULT 19
10: 00001880 0 SECTION LOCAL DEFAULT 20
12: 000006d0 0 NOTYPE GLOBAL DEFAULT 11 _fini
13: 00009830 0 NOTYPE GLOBAL DEFAULT ABS _gp
14: 00001880 0 NOTYPE GLOBAL DEFAULT ABS __bss_start
16: 00001830 4 OBJECT GLOBAL DEFAULT 17 j
17: 000005e0 96 FUNC GLOBAL DEFAULT 10 func_b
18: 00001884 0 NOTYPE GLOBAL DEFAULT ABS _end
19: 00001880 0 NOTYPE GLOBAL DEFAULT ABS _edata
20: 000003d8 0 NOTYPE GLOBAL DEFAULT 8 _init
. And for the 'dynamic' linker, I put some relocating codes to the machine dependent function 'elf_machine_rela' of '/nios2gcc4/src/glibc-ports-2.5/sysdeps/nios2/dl-machine.h'. Unfortunately this relocation rewrites the 'text' section, so we must set the flag of elf's 'Program Headers' like
Program Headers:
Type Offset VirtAddr PhysAddr FileSiz MemSiz Flg Align
LOAD 0x000000 0x00000000 0x00000000 0x00738 0x00738 RWE 0x1000 <-- Flg must be RWE instead of R E.
LOAD 0x000738 0x00001738 0x00001738 0x0012c 0x0012d RW 0x1000
DYNAMIC 0x00074c 0x0000174c 0x0000174c 0x000c8 0x000c8 RW 0x4
. Now I can't do this through the linker, so now I used a 'binary editor' and rewrote it. Anyway, we can make the position dependent codes to shared libraries, but we need switches '-Bsymbolic' and '-G0' (this is needed to avoid the use of gp register for optimization), instead of '-fPIC'. I'm not sure that this direction is right or not. Kazu
