17 years agoLinux with MMU on NEEK
Hi, all. I'm testing Linux MMU version, on my NEEK. http://www.nioswiki.com/linux It works fine and I can use "bash" shell. This is the evident proof that we are using the true 'fo...
16 years agoHi,
I'm testing the dynamic linker and shared libraries of Nios system. Once I experienced that the static library 'libnano-X.a' generates SIGSEGV and I believed that this was caused by the wrong relocation of 'ld.so.1'. For example,
00017328 <GrSetErrorHandler>:
17328: defffc04 addi sp,sp,-16
1732c: dc400015 stw r17,0(sp)
17330: 044000f4 movhi r17,3
17334: 8c63be04 addi r17,r17,-28936
17338: dd400215 stw r21,8(sp)
1733c: 202b883a mov r21,r4
17340: 8809883a mov r4,r17
17344: dfc00315 stw ra,12(sp)
17348: dcc00115 stw r19,4(sp)
1734c: 0008ac40 call 8ac4 <_init+0x408> <----- this address must be relocated as loading adr. + 0x8ac4.
17350: d4e29517 ldw r19,-30124(gp)
17354: 8809883a mov r4,r17
17358: d5629515 stw r21,-30124(gp)
1735c: 00087a00 call 87a0 <_init+0xe4> <----- this address must be relocated as loading adr. + 0x87a0.
17360: 9805883a mov r2,r19
17364: dfc00317 ldw ra,12(sp)
17368: dd400217 ldw r21,8(sp)
1736c: dcc00117 ldw r19,4(sp)
17370: dc400017 ldw r17,0(sp)
17374: dec00404 addi sp,sp,16
17378: f800283a ret
but the result is as follows.
0x2aae3328: addi sp,sp,-16
0x2aae332c: stw r17,0(sp)
0x2aae3330: movhi r17,3
0x2aae3334: addi r17,r17,-28936
0x2aae3338: stw r21,8(sp)
0x2aae333c: mov r21,r4
0x2aae3340: mov r4,r17
0x2aae3344: stw ra,12(sp)
0x2aae3348: stw r19,4(sp)
0x2aae334c: call 0x20008ac4 <----- Wrong relocation?
0x2aae3350: ldw r19,-30124(gp)
0x2aae3354: mov r4,r17
0x2aae3358: stw r21,-30124(gp)
0x2aae335c: call 0x200087a0 <----- Wrong relocation?
0x2aae3360: mov r2,r19
0x2aae3364: ldw ra,12(sp)
0x2aae3368: ldw r21,8(sp)
0x2aae336c: ldw r19,4(sp)
0x2aae3370: ldw r17,0(sp)
0x2aae3374: addi sp,sp,16
0x2aae3378: ret
. But the real fact is that no one relocates these codes. These codes are already relocated by the (static-) linker, and the elf-header has no relocating information when it's loaded to the memory. With the switch '-shared', we can avoid this situation, but if we indicate an option switch '-prefer-non-pic' for shared libraries, the same thing will occur. Next code is the disassemble result of 'libmpeg2.so'.
00004660 <mpeg2_init>:
4660: d0a03017 ldw r2,-32576(gp)
4664: defffb04 addi sp,sp,-20
4668: dcc00315 stw r19,12(sp)
466c: dc800215 stw r18,8(sp)
4670: dfc00415 stw ra,16(sp)
4674: dc400115 stw r17,4(sp)
4678: dc000015 stw r16,0(sp)
467c: 04c00044 movi r19,1
4680: 0025883a mov r18,zero
4684: 10003226 beq r2,zero,4750 <mpeg2_init+0xf0>
4688: 000b883a mov r5,zero
468c: 0111a004 movi r4,18048
4690: 00019bc0 call 19bc <_init+0xbc> <---- here, we must relocate, but...
4694: 01802004 movi r6,128
4698: 000b883a mov r5,zero
469c: 10002426 beq r2,zero,4730 <mpeg2_init+0xd0>
. Of course, if these codes are linked as normal executables, these relocations will not make any troubles. Kazu
