17 years agoLinux with MMU on NEEK
Hi, all. I'm testing Linux MMU version, on my NEEK. http://www.nioswiki.com/linux It works fine and I can use "bash" shell. This is the evident proof that we are using the true 'fo...
16 years agoHi,
--- Quote Start --- I had the cache changed in the custom design to the minimum as in the NEEK design (it was 8+8k) and the ethernet works now. *headdesk* My theory is something isn't getting flagged properly for uncached IO and using the smaller cache just happens to avoid caching those bits. --- Quote End --- I have a little bit doubt that Nios CPU with MMU can't have over 4Kbytes caches. There are several ways of connecting method for CPU, cache and MMU. For example, 1) CPU -- cache -- MMU -- Memory 2) CPU -- MMU -- cache -- Memory. The first method has low latency, but also has 'synonym problems'. The second method accesses the cache by physical addresses, but has larger latency to the contrary. So I think that Nios CPU takes the next strategy i.e. 3) CPU |--cache --| -- Memory ............|--MMU --| by limiting the size of cache under page size.(Please refer Nios handbook n2cpu_nii5v1.pdf, page 2-10, Figure 2-2.) If so, we can't have both instruction and data caches larger than page size(=4Kbytes). Kazu
