17 years agoLinux with MMU on NEEK
Hi, all. I'm testing Linux MMU version, on my NEEK. http://www.nioswiki.com/linux It works fine and I can use "bash" shell. This is the evident proof that we are using the true 'fo...
16 years agoHi,
--- Quote Start --- dhcpcd doesn't work, with either driver I get:dhcpcd: terminating on signal 7and it takes down eth0 if it was previously brought up with ifconfig. It's a SIGBUS so probably another incorrect memory access issue. --- Quote End --- I think that you are using the dhcpcd of 'dhcpcd-new' directory(Mr.Yoichi Hariguchi's dhcpcd will claim 'ioctl SIOCSIFBRDADDR (ifConfig): Cannot assign requested address' and not work). So I debugged the new dhcpcd and found that the error is caused by calling a function ' memset' in the file 'client.c'
void *dhcpReboot()
dhcpStart();
memset(&DhcpOptions,0,sizeof(DhcpOptions)); // <- This calling will generate a signal SIGSEGV in my debugger.
memset(&DhcpIface,0,sizeof(dhcpInterface));
if ( readDhcpCache() )
This may be a dynamic linking error, but I don't know the reason exactly. Kazu
