17 years agoLinux with MMU on NEEK
Hi, all. I'm testing Linux MMU version, on my NEEK. http://www.nioswiki.com/linux It works fine and I can use "bash" shell. This is the evident proof that we are using the true 'fo...
16 years agoAfter these repairs, we must make two files, i.e. kgdb.c and its header, and place those in the directories of Nios Arch (kernel & include/asm). The samples are as follows
* NIOS2 KGDB support
* Copyright (C) 2009 Nios Community Wiki
* This file is subject to the terms and conditions of the GNU General Public
* License. See the file "COPYING" in the main directory of this archive
* for more details.
*/# include <linux/kgdb.h># include <linux/kdebug.h># include <linux/irq.h># include <linux/io.h># include <asm/cacheflush.h>
static int wait_for_remote_debugger;
* Replace the instruction immediately after the current instruction
* (i.e. next in the expected flow of control) with a trap instruction,
* so that returning will cause only a single instruction to be executed.
* Note that this model is slightly broken for instructions with delay
* slots (e.g. BS, BSR, BRA etc), where both the branch and the
* instruction in the delay slot will be executed.
void pt_regs_to_gdb_regs(unsigned long *gdb_regs, struct pt_regs *regs)
gdb_regs = 0;
gdb_regs = regs->r1;
gdb_regs = regs->r2;
gdb_regs = regs->r3;
gdb_regs = regs->r4;
gdb_regs = regs->r5;
gdb_regs = regs->r6;
gdb_regs = regs->r7;
gdb_regs = regs->r8;
gdb_regs = regs->r9;
gdb_regs = regs->r10;
gdb_regs = regs->r11;
gdb_regs = regs->r12;
gdb_regs = regs->r13;
gdb_regs = regs->r14;
gdb_regs = regs->r15;
gdb_regs = regs->ra;
gdb_regs = regs->fp;
gdb_regs = regs->sp;
gdb_regs = regs->gp;
gdb_regs = regs->estatus;
gdb_regs = regs->ea;
void gdb_regs_to_pt_regs(unsigned long *gdb_regs, struct pt_regs *regs)
regs->r1 = gdb_regs;
regs->r2 = gdb_regs;
regs->r3 = gdb_regs;
regs->r4 = gdb_regs;
regs->r5 = gdb_regs;
regs->r6 = gdb_regs;
regs->r7 = gdb_regs;
regs->r8 = gdb_regs;
regs->r9 = gdb_regs;
regs->r10 = gdb_regs;
regs->r11 = gdb_regs;
regs->r12 = gdb_regs;
regs->r13 = gdb_regs;
regs->r14 = gdb_regs;
regs->r15 = gdb_regs;
regs->ra = gdb_regs;
regs->fp = gdb_regs;
regs->sp = gdb_regs;
regs->gp = gdb_regs;
regs->estatus = gdb_regs;
regs->ea = gdb_regs;
void sleeping_thread_to_gdb_regs(unsigned long *gdb_regs, struct task_struct *p)
gdb_regs = p->thread.kregs->sp;
gdb_regs = p->thread.kregs->ea;
int kgdb_arch_handle_exception(int e_vector, int signo, int err_code,
char *remcomInBuffer, char *remcomOutBuffer,
struct pt_regs *linux_regs)
unsigned long addr;
char *ptr;
int cpu = smp_processor_id();
switch (remcomInBuffer) {
case 's':
case 'c':
/* handle the optional parameter */
ptr = &remcomInBuffer;
if (kgdb_hex2long(&ptr, &addr))
linux_regs->ea = addr;
case 'D':
case 'k':
atomic_set(&kgdb_cpu_doing_single_step, -1);
if (remcomInBuffer == 's')
atomic_set(&kgdb_cpu_doing_single_step, cpu);
return 0;
/* this means that we do not want to exit from the handler: */
return -1;
/* KGDB Breakpoint handler */
asmlinkage void kgdb_breakpoint_c(struct pt_regs *fp)
/* The breakpoint entry code has moved the PC on by 4 bytes, so we must */
/* move it back. This could be done on the host but we do it here */
if (!wait_for_remote_debugger)
fp->ea -= 4;
else /* pass the first trap 0x1e code */
wait_for_remote_debugger = 0;
//printk("KGDB Breakpoint detected, instr=0x%08lx ea=0x%08lx ra=0x%08lx sp=0x%08lx\n", *(unsigned long*)fp->ea, fp->ea, fp->ra, fp->sp);
kgdb_handle_exception(30, SIGTRAP, 0, fp);
//printk("GOOD LUCK!! instr=0x%08lx ea=0x%08lx\n", *(volatile unsigned long*)fp->ea, (volatile unsigned long*)fp->ea);
int kgdb_arch_init(void)
wait_for_remote_debugger = 1;
return 0;
void kgdb_arch_exit(void)
struct kgdb_arch arch_kgdb_ops = {
/* Breakpoint instruction: trap# 0x1e */
.gdb_bpt_instr = { 0xba, 0x6f, 0x3b, 0x00 },
# ifndef __ASM_NIOS2_KGDB_H# define __ASM_NIOS2_KGDB_H
# include <asm/cacheflush.h># include <asm/ptrace.h>
enum regnames {
GDB_R0, GDB_AT, GDB_R2, GDB_R3, GDB_R4, GDB_R5, GDB_R6, GDB_R7,
GDB_R8, GDB_R9, GDB_R10, GDB_R11, GDB_R12, GDB_R13, GDB_R14, GDB_R15,
GDB_R16, GDB_R17, GDB_R18, GDB_R19, GDB_R20, GDB_R21, GDB_R22, GDB_R23,
GDB_ET, GDB_BT, GDB_GP, GDB_SP, GDB_FP, GDB_EA, GDB_BA, GDB_RA,
GDB_PC, GDB_ST, GDB_EST, GDB_BST, GDB_IE, GDB_IP, GDB_CID, GDB_CT6,
GDB_EX, GDB_PTE, GDB_TBA, GDB_TBM, GDB_CT11,GDB_BAD, GDB_CFG,
# define NUMREGBYTES ((GDB_CFG + 1) * 4)
static inline void arch_kgdb_breakpoint(void)
__asm__ __volatile__ (".word 0x003b6fba");
/* State info */
extern char in_nmi; /* Debounce flag to prevent NMI reentry*/
# define BUFMAX 2048
# define CACHE_FLUSH_IS_SAFE 1# define BREAK_INSTR_SIZE 4
# endif /* __ASM_NIOS2_KGDB_H */
And I'm using the code 'trap 30' as software break point ones, we must add some codes to '/home/***/nios2-linux/linux-2.6/arch/nios2/kernel/entry.S'
trap_table:
.word handle_system_call // 0
.word instruction_trap // 1
.word instruction_trap // 2
.word instruction_trap // 3
.word instruction_trap // 4
.word instruction_trap // 5
.word instruction_trap // 6
.word instruction_trap // 7
.word instruction_trap // 8
.word instruction_trap // 9
.word instruction_trap // 10
.word instruction_trap // 11
.word instruction_trap // 12
.word instruction_trap // 13
.word instruction_trap // 14
.word instruction_trap // 15
.word instruction_trap // 16
.word instruction_trap // 17
.word instruction_trap // 18
.word instruction_trap // 19
.word instruction_trap // 20
.word instruction_trap // 21
.word instruction_trap // 22
.word instruction_trap // 23
.word instruction_trap // 24
.word instruction_trap // 25
.word instruction_trap // 26
.word instruction_trap // 27
.word instruction_trap // 28
.word instruction_trap // 29# ifdef CONFIG_KGDB
.word handle_kgdb_breakpoint // 30 KGDB breakpoint# else
.word instruction_trap // 30# endif
.word handle_breakpoint // 31
and
handle_diverror:
call handle_illegal_c
br ret_from_exception
# ifdef CONFIG_KGDB
handle_kgdb_breakpoint:
call kgdb_breakpoint_c
br ret_from_exception# endif
* Beware - when entering resume, prev (the current task) is
. And repair the Kconfig file '/home/***/nios2-linux/linux-2.6/lib/Kconfig.kgdb' as
config HAVE_ARCH_KGDB
bool
menuconfig KGDB
bool "KGDB: kernel debugging with remote gdb"# depends on HAVE_ARCH_KGDB
depends on DEBUG_KERNEL && EXPERIMENTAL
help
If you say Y here, it will be possible to remotely debug the
kernel using gdb. It is recommended but not required, that
you also turn on the kernel config option
CONFIG_FRAME_POINTER to aid in producing more reliable stack
backtraces in the external debugger. Documentation of
kernel debugger is available at http://kgdb.sourceforge.net
as well as in DocBook form in Documentation/DocBook/. If
unsure, say N.
, you can select the item of 'kgdb' in the menuconfig. So select Kernel hacking ---> [*] Kernel debugging [*] Compile the kernel with debug info [*] KGDB: kernel debugging with remote gdb ---> <*> KGDB: use kgdb over the serial console (kgdboc=ttyS0, 115200 kgdbwait) Default kernel command string and make your kernel again. (There is nothing that I'd forgotten to write, maybe... Opps, don't forget to add 'obj-$(CONFIG_KGDB) += kgdb.o' to the Makefile '/home/***/nios2-linux/linux-2.6/arch/nios2/kernel/Makefile'.:p) After getting the kmsg KGDB: Waiting for remote debugger evoke 'gdb' by 'nios2-wrs-linux-gnu-gdb -b 115200' and we can connect the 'kgdb' to our PC with a command e.g. 'target remote /dev/ttyS*'. After the connection, by setting some breakpoints e.g. symbol-file vmlinux b load_elf_binary continue , we can make break at the first program loading. Happy Debugging ! (and I shoud debug kgdb.c with KGDB.:D) Kazu
