17 years agoLinux with MMU on NEEK
Hi, all. I'm testing Linux MMU version, on my NEEK. http://www.nioswiki.com/linux It works fine and I can use "bash" shell. This is the evident proof that we are using the true 'fo...
16 years agoHi.
I ported a SD-SPI IP to my NEEK according to the instructionhttp://www.alteraforum.com/forum/showthread.php?t=18875 . The boot messages are
mmc_spi spi2.0: ASSUMING SPI bus stays unshared!
mmc_spi spi2.0: ASSUMING 3.2-3.4 V slot power
mmc_spi spi2.0: SD/MMC host mmc0, no DMA, no WP, no poweroff
TCP cubic registered
NET: Registered protocol family 17
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
mmc0: host does not support reading read-only switch. assuming write-enable.
mmc0: new SD card on SPI
mmcblk0: mmc0:0000 SD01G 968 MiB
mmcblk0:
. So I hit the command 'mount -t vfat /dev/mmcblk0 /mnt', but it claims 'No such device or address'. I wondered and searched the cause in the kernel carefully, but could'nt find the bug. It clearly initializes the SD driver and reads informations... Finally I saw the Manpage of 'mount(2)' and knew the exact meaning of 'ENXIO'. It saies that 'The major number of the block device source is out of range'. In the file '/home/***/nios2-linux/uClinux-dist/vendors/Altera/nios2/device_table.txt' # mmc block devices
/dev/mmc0 b 640 0 0 197 0 0 1 -
/dev/mmcblk0 b 640 0 0 197 0 0 1 -
/dev/mmcblk0p1 b 640 0 0 197 1 0 1 -
/dev/mmcblk0p2 b 640 0 0 197 2 0 1 -
/dev/mmcblk0p3 b 640 0 0 197 3 0 1 -
Of cource, the true major number of 'mmc' is 179... Hey, Give me a break! Kazu
