17 years agoLinux with MMU on NEEK
Hi, all. I'm testing Linux MMU version, on my NEEK. http://www.nioswiki.com/linux It works fine and I can use "bash" shell. This is the evident proof that we are using the true 'fo...
17 years agoHi.
--- Quote Start --- I want to make 'core dump', but the kernel will not output those. Of course, I set 'ulimit -c unlimited'. --- Quote End --- This was only the kernel configuration problem. In the 'menuconfig', [* ] Customize Kernel Settings (NEW)-> Exit->Exit-> General setup ---> [*] Enable ELF core dumps so, we can get the 'core dump' with 'ulimit -c unlimited'. By setting
echo 1 > /proc/sys/kernel/print-fatal-signals
cat /proc/sys/kernel/print-fatal-signals
1we can get simple register's information. About 'fltk' demo program's 'Segmentation fault', it seems some bugs of libraries.:mad: Kazu
