16 years agoLinux with MMU: inetd and telnetd problem
hi all: After run a uclinux, I try to use the linux with MMU. At first is the inetd can't find serveces. I close the "Cull unused ELF shared libraries" and compile, >Blackfin build options ...
16 years agojust turn on "Build BusyBox as a static binary (no shared libs)" and telnetd ok.
[root@localhost uClinux-dist]# telnet 192.168.1.235 Trying 192.168.1.235... Connected to localhost (192.168.1.235). Escape character is '^]'. nios2 login: root Welcome to ____ _ _ / __| ||_| _ _| | | | _ ____ _ _ _ _ | | | | | | || | _ \| | | |\ \/ / | |_| | |__| || | | | | |_| |/ | ___\____|_||_|_| |_|\____|\_/\_/ | | |_| //////////////////////// target: /# netstat -a Active Internet connection (servers and established) Proto Recv-Q Send-Q Local Address Foreign Address state tcp 0 0 (null):ftp (null):* LISTEN tcp 0 0 (null):telnet (null):* LISTEN tcp 0 0 (null):telnet (null):2209 ESTABLISHED Active UNIX domain sockets (servers and established) Proto RefCnt Flags Type State I-Node Path /# login[654]: root login on 'ttyp0' from '192.168.1.202'
