10 years agoLinux gives error while reading micro SD card to mount root filesystem
Hi all, I've been trying to bring upsocfpga-linux provided by SoC EDS 15.1.1.60 on Altera Arria 10 boardwith my own hardware design. As the kernel comes up and tries to readSD card to mount roo...
10 years ago --- Quote Start --- Your problem is likely because of this:
systemd: Failed to insert module 'autofs4': Function not implemented
systemd: Failed to insert module 'ip_tables': Function not implemented Make sure the kernel modules named (ip_tables most likely is the problem here) are installed an loaded correctly. --- Quote End --- Thanks for the reply. I observed that the toolchain I downloaded is corrupted due to some firewall installed in my company. After I installed a fresh toolchain and compiled, the issue got resolved. Just want to know: Does the toolchain do anything w.r.to inserting the modules autofs4 and iptables? I mean, does the toolchain have any library which the kernel/rootfs makes use of for inserting these modules?
