10 years agoLinux gives error while reading micro SD card to mount root filesystem
Hi all, I've been trying to bring upsocfpga-linux provided by SoC EDS 15.1.1.60 on Altera Arria 10 boardwith my own hardware design. As the kernel comes up and tries to readSD card to mount roo...
10 years agoYour problem is likely because of this:
systemd: Failed to insert module 'autofs4': Function not implemented
systemd: Failed to insert module 'ip_tables': Function not implemented Make sure the kernel modules named (ip_tables most likely is the problem here) are installed an loaded correctly.
