10 years agoLinux gives error while reading micro SD card to mount root filesystem
Hi all, I've been trying to bring upsocfpga-linux provided by SoC EDS 15.1.1.60 on Altera Arria 10 boardwith my own hardware design. As the kernel comes up and tries to readSD card to mount roo...
10 years ago --- Quote Start --- I'm no Linux expert but "ERROR: could not get clock /sopc@0/dma@0xffda1000:apb_pclk(0)" doesn't look good. If DMA isn't working you won't be reading anything from your SD card. I'm not saying this is the case, but it's worth getting a Linux expert to take a look. Thanks for the reply. I assume your preloader and uboot are both on the SD card. This means the basic SD hardware is working. I think that neither preloader nor uboot use DMA, so the first use of DMA is in the Linux kernel. --- Quote End --- Yes, both preloader and uboot are in SD card. Good information about DMA; Let me check it.
