10 years agoLinux driver for PCIe DE2i-150
Hello guys, who can help I am in search of PCIe driver for Linux for DE2i-150 board. thank you for your attention
10 years ago --- Quote Start --- If you don't use the supplied software, you are on your own on getting drivers. Quite often it isn't worth the trouble of using something other than what came with your board even if it is a bit outdated. My advise it to stick with the Yocto distribution that came with the board. Forget about using Ubuntu unless you have considerable Linux knowledge. You should probably consult a Linux kernel expert (which I am not) for this. Sorry I couldn't be of help. --- Quote End --- Hello, a colleague of mine ever encountered these sources since, but we're not lying to you more. In addition, it should be better known because of the software license that is GPL, and requires sources become available.
