20 years agolinker question
hello, In my project, some global variables are placed in a library. These variables are used in a class that also has a global instance in that library. The constructor of that class places po...
20 years agoThe problem is not the filesystem itself. It works with other files that already are in the system (but not in a library for the moment)
The problem is some instances of File (or a derived version of File). Because the Filesystem::Open() uses a character string (the filename) to look up what the File instance is to use. So if the tftp server is getting a request for the "testdata.txt", the FileSystem looks for the File instance attached to that name, and returns a pointer to TestDataFile (see examples in my previous post). Here the TestDataFile is never accessed elsewhere in the code directly, and this is exactly what I want to achieve : some parts of the software generate some files with information about the system, without interaction with the main part of the software. It should be stupid if I have to change other parts of the sw if I add a file somewhere. I can understand your point about the singleton, but I think it will not help me, because in the source file with the problems, I don't need the FileSystem at all. It is the web server (or tftp, ... server) that uses the static FileSystem (Filesystem is a class with all static members, and has no real instance). Stefaan
