16 years agoKernel panic - not syncing: broken padding
I'm testing MMU Linux and have a strange phenomena.
I have stored my kernel 'linux.initramfs.gz' in flash using elf2flash and then nios2-flash-programmer (with the option '--mmu'). When I'm turning the board on, the boot fails on a 'Kernel panic - not syncing: broken padding'. However, when I'm resetting the CPU (using the CPU reset switch), the boot is running fine without error. I suppose it is a problem of MMU configuration that the bootloader doesn't perform but the kernel do, but I am not sure? Is there another solution to boot as fast as possible a Linux kernel? Have I to use 'uboot'? And if so, is it possible to make uboot starting with no delay nor query? TIA for any idea, -- FredNo RepliesBe the first to reply
