19 years ago
kernal build error
dear hippo,
Thank you help me , now i bulild the kernal in my custom board (EP1C6,SDRAM(8MB),FLASH(8MB),uart *2,jtat uart ) ,when i run menuconfig ,i
select the ALTERA JTAG UARTsupport,and the nios serial support, then compile :
[wangzhiwunpu@localhost linux-2.6.x]$ make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc-
no emulation specific options.
CHK include/nios2_system.h
CHK include/linux/version.h
SPLIT include/linux/autoconf.h -> include/config/*
CC init/main.o
CHK include/linux/compile.h
CC init/do_mounts.o
LD init/mounts.o
LD init/built-in.o
CHK usr/initramfs_list
CC arch/nios2nommu/kernel/signal.o
CC arch/nios2nommu/kernel/setup.o
CC arch/nios2nommu/kernel/start.o
arch/nios2nommu/kernel/start.c: In function `main':
arch/nios2nommu/kernel/start.c:523: warning: label `badshiftci_label' defined but not used
LD arch/nios2nommu/kernel/built-in.o
CC kernel/printk.o
CC kernel/exit.o
CC kernel/signal.o
CC kernel/sys.o
CC kernel/power/console.o
LD kernel/power/built-in.o
CC kernel/acct.o
LD kernel/built-in.o
CC fs/open.o
CC fs/dquot.o
CC fs/devpts/inode.o
LD fs/devpts/devpts.o
LD fs/devpts/built-in.o
CC fs/proc/array.o
CC fs/proc/proc_tty.o
CC fs/proc/proc_misc.o
LD fs/proc/proc.o
LD fs/proc/built-in.o
LD fs/built-in.o
CC drivers/char/mem.o
drivers/char/mem.c: In function `mmap_kmem':
drivers/char/mem.c:276: warning: cast to pointer from integer of different size
CC drivers/char/tty_io.o
In file included from include/linux/selection.h:11,
from drivers/char/tty_io.c:104:
include/linux/vt_buffer.h:19:21: asm/vga.h: No such file or directory
make[2]: *** [drivers/char/tty_io.o] Error 1
make[1]: *** [drivers/char] Error 2
make: *** [drivers] Error 2
    Dear hippo:
    I just do as you tell me,and i got the zImage.Then i download the zImage into DE2,but these happened:
    nios2-download -g zImage
    Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
    pausing target processor http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/ohmy.gif K
    Initializing CPU cache(if present)
    Downloaded 1440KB in 17.9s (80.4KB/s)
    Verified OK
    Starting processor at address 0x005000000
    nios2-terminal
    uncompressing Linux ......OK,booting the kernel.
    That is all! Where the rest?
    I enable these:
    Virtual terminal
    Support for console on virtual terminal
    Altera JTAG UART support
    Support for console on Altera JTAG UART
    Good, you are very close.
    If I show some config UNSELECTED in the wiki, it means you should not select it.
    [ ] Support for console on virtual terminal # YOU SHOULD NOT SELECT THIS
