15 years agoJTAG USB dropping data when printing to terminal
I've got a system setup to print out ADC samples via a NIOS processor (standard) and JTAG USB. The ADC samples at 48Khz and the samples are streamed to the NIOS processor to be printed through PIO. ...
15 years agoIncreasing the JTAG UART buffer from the default 64 bytes to 8192 bytes shows no difference. Changing from a NIOS/s to NIOS/f processor causes the same numbers to be repeated every time (ie they are never updated as shown below):
1hz 10hz 100hz 1khz 10khz 100khz 1Mhz 27Mhz 50Mhz C counter
74 24 40 96 40 95 33 18 37 1
74 24 40 96 40 95 33 18 37 2
74 24 40 96 40 95 33 18 37 3
74 24 40 96 40 95 33 18 37 4
74 24 40 96 40 95 33 18 37 5
74 24 40 96 40 95 33 18 37 6
74 24 40 96 40 95 33 18 37 7
74 24 40 96 40 95 33 18 37 8
74 24 40 96 40 95 33 18 37 9
74 24 40 96 40 95 33 18 37 10
74 24 40 96 40 95 33 18 37 11
74 24 40 96 40 95 33 18 37 12
74 24 40 96 40 95 33 18 37 13
74 24 40 96 40 95 33 18 37 14
74 24 40 96 40 95 33 18 37 15
74 24 40 96 40 95 33 18 37 16
NIOS/s, 8192 JTAG UART buffer:
39 83 9 92 0 97 54 96 76 1991
39 83 9 93 16 53 16 85 2 1992
39 83 9 94 19 86 47 97 5 1993
39 83 10 95 35 44 28 97 79 1994
39 83 10 96 39 80 83 49 70 1995
39 83 10 99 67 55 41 53 37 1996
39 83 10 99 70 91 95 68 56 1997
39 83 10 101 95 28 75 52 0 1998
